Hello everyone I’m new to this forum. I’ve read through hundreds of threads but I’m still lost. I have a 1990 Tracker 4x4 5sp 1.6 8v with 38k that is not getting an injection pulse. So far I have replaced the fuel pump and the three capacitors in the ecm(33920-60A32) but still no injection pulse. I tried the noid light test on the injector wires and to no avail. It also seems that I may have no tach signal but I’m unsure on how to test for it. It runs well off of test fuel so I know I have spark and compression. Here is some additional info that may be applicable. The car sat for about 4 years prior to me buying it. When I first started working on it I tried starting it with some ether and I did have a tach reading then but now it points pretty much down. No CEL with key on or while it is cranking. Also tried to pull codes but the engine light does not light up at all so I’m thinking the bulb is bad. Any advice would be greatly appreciated.
Thanks, Dave
Thanks, Dave
