Alright I bought a samurai with 31 inch tires and with about a 4 inch lift and the back has the yj stuff done but not the front yet. The guy before me installed the 1.6 8 valve motor and the sidekick tranny also. It has lockrite lockers in front and back. Whenever i turn it clicks and when i let go of the clutch the sammi wants to pull to the left. not bad just when i dump the clutch. ANy it hops alot when i am climbing which isnt a good thing at all.
It is normal for a locker to click when you turn a corner, this is the locker letting go so you can get around the turn with out dragging a wheel. Check the front end and see if you have a bad bearing or a dragging brake also check alinement. If your tires are hopping when climbing a hill try lowering your air pressure and see if that helps, keep in mind that the samurai isn't very heavy so it won't take as much to get it to bounce.
Or. you have a bump steer problem and an axle rap issue. Resurch both subjects for tech.
Both are very commen problems.
