2008 SX4 AWD, 2.0/16 valve, manual transmission, 100,000 miles, Wisconsin. So far digging my SX4, but going through maintenance procedures. Questions for experienced owners:
Fluid Specs and Capacities:
* manual transaxle oil (spec and capacity)
* transfer oil (spec and capacity)
* rear differential oil (spec and capacity)
Also, my AC does not work, so I assume its a clutch issue, as the relay and fuse are good, condenser fans activates. I orderd an reman clutch/compressor.
Also, in the manual it states check valve lashing - are these hydraulic?
Your input is most appreciated!! ...Mac
diff 0.8 L 1.7 us pint
xfer 0.6 litre 1.2 us pint
manual trans 2.5 litres 5.3 us pints
from the user manual...going to the shop manual (2007-2009) for grades.....
NOTE Differential oil specification
• Hypoid gear oil must be used for
differential.
• It is highly recommended to use API GL-5
80W-90 gear oil.
: API GL-5 (For SAE classification, refer to viscosity chart [A] in figure.)
Rear differential oil capacity
Reference: 0.7 – 0.9 liters (1.5/1.2 – 1.9/1.6 US Imp. pt.)
NOTE Transfer oil specification
80W-90 gear oil.
Transfer oil capacity
Reference: 0.6 liters (1.2/1.0 US/lmp. pt)
NOTE Transaxle oil specification
It is highly recommended to use API GL-4
75W-90 gear oil.
API GL-4 (For SAE classification, refer to viscosity chart [A] in figure.)
Transaxle oil capacity
Reference: 2.5 liters (5.3/4.4 US/lmp. pt.)
