1 - 20 of 22 Posts
Purchased this 2000 Tracker for my wife earlier this week. It's in great shape, with 65K on the clock. Just have a couple issues that maybe ya'll could point me in the right direction. It's a 4 door, 2.0 I4, auto, 4X4.
Issue one, when the engine reaches operating temperature, in Drive/reverse at idle, the rpms seem low (500-600), and the car vibrates pretty bad. It's worse in reverse. I tested IAC motor by turning the steering wheel and making sure idle increased, and unplugging the A/c compressor and cutting the A/c on. Idles increased correctly. I'm waiting on my next paycheck to pick up a bluetooth OBD2 connector so I can read live data/fault codes. Don't have a scan tool in my shop that I can use on the tracker.
Issue two. Intermittently at night, headlights/instrument cluster lights, interior lights/radio pulsate. I'm suspecting it's a ground issue. May run an extra ground off the battery to the frame because the factory grounds look somewhat weak. Alternator is charging well, 14.4 volts idle/no loads, and 14 volts with a lot of loads turned on (a/c, radio, high beams, hazards, etc.)
Three. May not be an issue, might be normal. But driving/sitting still, transfer case shifter vibrates/shakes. Just curious if this is a sign of the transmission mount going out.
Anyhow here's a couple picks of the wife's new tracker.
Congrats on you find I too am also a new 2000 grand Vitara owned I found a 2000 GV 2.5 with 63,400 miles on it I got it cheep for $2300.00 from a Lil-old Lady
I had a small Idle problem when I got mine I changed out the air cleaner and it fixed it went from 500 rpm to 700 rpm nice and smooth It also has a broken throttle cable that bye the way was part of a recall and never fixed I have a appt for it in a week
A new ground is always a good idea but I would run 2 1 to the block and 1 to the body
and yes the 4WD shiftier will always vibrate when the truck is running it is directly attached to the transfer case that is why there is a rubber boot around it
and remember a tune up wont hurt
good luck with it I hope your wife likes it
Found a snap of the ol' lady
... Philip
Not true Esty - the 4WD shifter is a two piece shifter with a rubber isolator that absorbs the vibrations - also - I have a 2.0, 5 speed, 4WD, once it's up to operating temperature, you can sit behind the wheel with the engine idling and the only way to tell is to look at the tachometer - no vibration whatsoever.
The reason for the rubber boot is to seal fumes etc. out.
Discussion Starter · #5 ·
So it Isnt supposed to move around? Hmm engine/transmission mounts might be worn out then...
If the idle rpm is low (and yours is) the engine will vibrate and everything will shake - idle rpms should be in the 700~800 rpm area with the a/c off and 750~850 with the a/c on - fix the idle problem and the vibrations will probably disappear.
FSM spec is 750 +/- 50 rpm (a/c off) and 800 +/- 50 rpm (a/c on)
Discussion Starter · #7 ·
Ok. I'll post back when I get a scanner and check live sensor data. Going to put new plugs in this weekend. Has a new airfilter.
To fix your pulsating lights replace the alternator because that is a problem with these vehicles. I replaced mine and no more problem. You can find it on ebay for about $110.00.
The cam sensors are also a known problem. f you vehicle shuts down and will not start until it cools down it's the cam sensor.
Not yet.....
Discussion Starter · #13 ·
Ok. Got my bluetooth adapter and torque app. The first two screen shots are at idle in park. Just a minute amount of vibration, second two are in reverse.
Would like to see a closed loop
graph of the B1S1 at idle and at 2000rpm, also
ECT at idle and 2000rpm..
.... Philip
Discussion Starter · #16 ·
.... Philip
Will do. I'll have to do it tomorrow since the weather here is bad. Do you want the idle graphs in park/reverse, etc? 2000rpm graphs moving or stationary? Thanks
It does not matter provided they are at a stead rpm (sustained)
on second thoughts do the ECT, both standing and at road speed..
.... Philip
Discussion Starter · #18 ·
OK got graphs of o2 b1s1 and ext at idle and 2000rpms. Had to do them stationary.
From left to right: o2/idle, o2/2k, ect/idle, ect/2k.
Have you checked for vacuum leaks?? It just sounds like a good fit.
Are the brakes hard? Check vacuum booster to.
1 - 20 of 22 Posts
