Do Suzuki supply the cars with the coating or is it something the dealer does. Do you use salt on the roads in Iceland, as we do in the Uk in winter?The corrosion plating is standard here in Iceland, all car dealers sell the cars with it
Yeah we use salt, and the dealer pays some company here in iceland to do itDo Suzuki supply the cars with the coating or is it something the dealer does. Do you use salt on the roads in Iceland, as we do in the Uk in winter?
Ours is a late 18 (registered) and it's back in the dealers tomorrow. Clonk on left cornering from the nearside rear as the suspension lifts.Mine's production spring 2019 and the rear shocks seem to have the same view as per photo but the bottom part tube of the absorber i see is arround 4cm diameter and not 2,5 which stated.
Seem to be the upgraded ones?
I haven't yet used car fully laded yet but i notice some clunks/and intense car's shaking even only driver or 3-4 persons..
Actually is a lot lightweight so part of expecting a little due to this?
If the drum is moving relative to the backplate, it’s hardly surprising you’re having problems with rear brake adjustment! Potentially dangerous to drive a car in this condition and l‘m surprised at a dealer not taking immediate action.Ours is a late 18 (registered) and it's back in the dealers tomorrow. Clonk on left cornering from the nearside rear as the suspension lifts.
Dealer played dumb until I said it got worse after having a passenger in the back. I don't like the flex in the half shaft, disconcerting to see a drum moving and the back plate not.
I too seem to have the upgraded shocks.
Either the wheel bearings are moving in the housing or possible a bush moving as not pinched tight enough. Going to ask dealer to be in on the inspection when they do it.
Your right, on the service report they said they had tested a new vehicle to see and the new vehicle was the same so it's the way they are.If the drum is moving relative to the backplate, it’s hardly surprising you’re having problems with rear brake adjustment! Potentially dangerous to drive a car in this condition and l‘m surprised at a dealer not taking immediate action.
The correct rear shock absorbers should be around 38mm diameter on the cylindrical body. I’m not sure I understand the 32mm diameter - is this at the cylindrical section? if correct, it’s more akin to the original rather than the updated units. The letters DO are stamped on the shock absorbers in addition to the Suzuki part number. This may be causing confusion. As you point out, the suspension is going full travel and bottoming out at times.
