i have 3 neons i want to run to toggles but they r the ones with the cig adaptor on them. i noticed that they have a fuse in the adaptor do i need a inline fuse to run the 3 of them. Please n e one that can sugest how to install these. i also have underlight neons (streetglow optix) is there n e way i can run the 3 to the under kit
There is no way to run them with the under kit directly, but you can run them in parrallel off of the same switch. I would recomend putting a fuse somewhere in the circuit, either betweent the switch and battery or between the switch and the lights. I have found that they make a blade type holder that crimps in-line and it works really well and is easy to install and change the fuses.
