Will it turn over w/the starter? :huh:
If not, do you have a clutch safety switch (meaning the clutch pedal has to be depressed to start the vehicle) that you disturbed? Did you disturb the battery or starter WIRES proper?
IF it turns over...spray starting fluid in the intake.
If it fires...you have a no fuel issue (pump wiring? Out of fuel?). If it DOESN'T fire / run, you have disrupted the ignition system wiring.
