i have a 07 forenza wagon so having problems with leaking oveflow tank then a t part with three hoses conected was leaking then cracked, so then it started overheating, then started blowing hoses off then the radiator crack3d so i changed hoses, new raditor, resivior,hoses, t part. well we bleed it but does this car have a frickin bleed valve it is leaking out of the hose
check for blown head gasket. common problem with these. water in oil, fill tank full and see if bubbles when cranked, low compression,e.t.c.
