1 - 8 of 8 Posts
Anyone within driving distance of me that would like to change an alt (or get the dern torx bolt loose) in my 04 XL7??Will pay of course..I'm on the Ohio-Indiana border.Thanks in advance for any help.
Do you have the correct fitting Torx bit? 50 mm if I recall.
Another option is to remove the entire alternator WITH bracket and Torx fastener still in place, and then attack the Torx on the bench. Even remove / drill it out for a conventional hex head replacement bolt. ;)
Welcome aboard too.
Discussion Starter · #3 · (Edited)
Thanks for the welcome @Max Yeah i have the Torx bit.It started to strip as soon as i put some torque on it.I wasn't aware i could pull the alt with the Torx nut still attached.I did some looking around on the forum before posting and the most promising i seen was someone welded a broken bolt head onto the Torx and pulled it that way.
I don't have a welder and i have a really bad shoulder and back so that kind of limits what i can do.
I took it to a garage locally and they were kind of stuck on how to tackle it so i called off the repair.No use in them charging me $400.00 or so because it took them 3-4 hrs to figure it out.lol..I figured my best bet now would be to join a forum of people that REALLY know.
It got hung up in the site Spam program, so I pushed it through. ;)
Discussion Starter · #7 ·
H.O. alt installed.Just took off top bolt.Pried alt over and took it off brackets and all..Took the pita Torx bolt off when alt was out..Great voltage now on a big audio system. Thanks for the help.
Coolness! ;)
1 - 8 of 8 Posts
