This sounds strange to me, but here goes, I found water seeping out the bottom of my jeep and took to mechanic to see if he could find it cos I couldn't see it. He had to remove a couple of parts to find it and eventually moved the starter motor to find a hairline crack in the block! I don't understand It has never gotten hot or been off road and never leaked anything before, has low k's too.
Does this sound familiar to anyone?
Not uncommon if its been overheated.
Yes it does sound familiar, i had a 89 JLX Vitara a few years ago, that had a crack in the block, above the engine mount, thankfully, my Mech spotted it before i had some major work done on it... the older carby 1.6 engine block, was quite prone to this cracking...
I was advised by others to try a, " Chemiweld " additive as a cheap fix, and to get it welded, as a more expensive fix, but these were non permanent fixes... the only real way to fix it, is to replace the block... sadly it was out of my budget, so i had to sell the old Vitara... :(
