2013 Suzuki Grand Vitara
Hi guys. I have a 2013 Grand Vitara, The fuse block diagram calls out a 20A fuse labeled P/W T, see below, But as the next pic shows mine is not there. What does this fuse do, what does P/W T stand for? And do I need to purchase one.
Font Publication Temperature Number Auto part
Sleeve Electrical wiring Electronic device Wire Machine
This fuse in other vehicles is used for the power window timer function that allows the driver's window to still be operated for a short period after the ignition is switched off or until the door is opened. This may not be a feature in your vehicle, hence the absence of a fuse.
If its not factory fitted ( doesn't look like there's terminals in the empty hole) then leave it alone
I suspect the 30A p/w (without checking the service manual, power window) is the 4 door version, the 20A pw/t is the 3 door with timer
