1 - 1 of 1 Posts
trying to check the voltage on the mass air sensor, the 3 wires are color coded, which I can't tell apart , which wires are ground and which ones is the power? thanks.... car will start and run great than , going down the road it sometimes will die, than will start under compression ( 5 speed ) shows code p o 102, mass air sensor voltage however need to figure out which wires to use.....
1 - 1 of 1 Posts
