This is an old thread. Thought I'd add a little to it. I had Suzuki do the TSB on my 2012 before I bought it. When I test drove the car the gear shifter was VERY sloppy. See video. It says in the TSB to replace the lever seat and bushing if cracks or damage is found. Today I decided to look into it because even after the TSB work the gear shifter was very wobbly. And indeed, the seat was very damaged, see pic. Tomorrow I will contact Suzuki and ask them to give me a new seat. Cleary they didn't inspect properly. I'm not even sure the actually replaced ANYTHING...Well, the gear linkage in my 2009 has now been replaced. Feels like a new car! Improved the shift by miles, there's now only a couple of mm play in it, as opposed to the couple of cm that used to be there. Very happy.
Now to replace the cracked windscreen, and the second blown Ironman strut...
Thanks very much I'll see what happensAs far as I know no cars have been recalled in Europe. When you approach Suzuki with the TSB they will acknowledge it and do the repair. That's what I did. Show them this https://static.nhtsa.gov/odi/rcl/2017/RCMN-17V085-7454.pdf
I'm in Europe, Denmark.
Recall is expired as far as I know, its visible from the top if its one that's cracked. About an inch movement in gear at the knob is normal. My 2013 has been like that since newThanks for the fast reply.
Does have a bit of slop in there. Probably about an inch movable in gear. I did have the box surround out to add a USB port and didn't notice anything looking other than new. Is it visible from the top?
It does have an after market knob put on it which makes it longer, so it's a bit like driving a truck.
So what is the process with this? Just take it to a dealer and let them sort it? Is it even still valid?
Thanks again
