1988 Samurai
I lost my key and need to get the key lock cylinder or ignition lock cylinder out.
How do I do that? Any special tools needed?
2nd question: Is it worth changing the motor?
It doesn't pass smog as previous owner installed headers, Weber carburetor and disconnect emissions parts.
In CA I can change the engine to a pre-'97 diesel engine (one that is CA compliant which means from a car that was legal to sell new in CA, 50-state car)
I am considering installing a VW diesel engine. I found a kit for $1000 and i would need the labor and to buy engine.
Thank you.
Discussion Starter #2
Thanks for the responses. This group seems to be only a few people and only people who want to take free advice for repair instead of paying a professional.
FYI
I realized that the door locks and the ignition cylinder is keyed the same. I was wrong to think I had to remove the ignition lock.
When I called the locksmith for a price I was informed the key code can be found stamped on the passenger door lock cylinder.
Your local dealer may be able to give you a key code. I did not get a response from my dealer. Older vehicle are not supported by dealers and may not be of help.
That door lock cylinder is much simpler- remove inside door panel, disconnect linkage by removing c-clip holding linkage to lock cylinder, remove c-clip that holds lock cylinder in door, push lock cylinder out.
I only removed it because it was so easy and as insurance when I went to the locksmith. Key code may be able to be read with cylinder in the door after removing door panel.
Side note to saving money- prices may vary. Instead of going to the first locksmith I called 3. The 3rd person gave me a price of $18 vs the others $36. So I went and when I asked for a second key cut from the code she gave me both keys for $20 including tax cash. And only 1/2 mile away.
It pays to price compare.
Hope this helps somebody
Keep in mind that a locksmith cannot make a key from a lock for every type of lock that exists. Some locks have specific features that deter using a lock to make a key, and it is nearly impossible to have a key made without having access to the original key.
