1 - 9 of 9 Posts
OK here's a little background to this issue
Car ( Alto 2004 ) had recently been off-road following a collision . I have got it back on the road after repairing bodywork damage . Car had been off road for around 11 Weeks .
Car is now looking good, since repairing I have taken it for two test drives . THe first was fine , no serious issue for around 5 miles . Today however after around 8 miles of test driving , the car started misfiring and struggling around 2K revs when in any gear
My immediate thought was that this was a coil / spark issue . However after bringing the car home and sitting on drive , it revs comfortably in neutral - No misfiring . Why would it misfire only when accelerating in gear ? Would could it be a ignition/coil/spark issue if revving is fine in neutral ?
I am thinking maybe the petrol has caused some clogging in carb or perhaps something else . ANy thoughts or suggestions ?
It would be helpful if we knew what engine, and what market the vehicle was made for..
What type of fuel delivery (carb/FI) and what type of ignition (COP/cap and wire)
... Philip
2003 1.1 Alto Misfire on cylinder 4
Ok So I have an Update guys
I attached an OBD Reader and got a 'misfire on cylinder 4 error code' . Does anyone know which cylinder is cylinder 4?
I had checked the resistance on the coil packs , they seemed normal . I checked the Leads for continuity , they belled out ok also .
I have been led to suspect there could be a leak on the air intake manifold , or possibly a failing spark plug .
For the Record this Alto for the UK market year 2003/4 . I have attached a picture for us to identify its engine type
Here is the car :
The furthest (last) one, looking from the crank pulley / belts (front) on the engine.
Change out the spark plugs for new, first off. ;)
I guess Changing all four would be ideal , however at diagnosis stages I would rather just test with one . However if one stops the misfiring - I will replace all four
If I replace all four and it is still misfiring then I am tossing money needlessly
But thanks for the tip !
If after replacing the plugs, scan and if you still have the #4 mis-fire, swap #4 coil with any other cylinder coil, run it, re-scan and see if the code follows the coil. IF so, you have found a bad coil. :)
Discussion Starter #7 (Edited)
Good Idea
I did actually try swapping the coil packs , though didn't have a scan tool at the time . Though when swapping I did feel an obvious change in the misfiring . So you may be right about the coil pack
The strange thing is ; on the fluke meter , I compared resistance readings between the coil packs , and they read out the same :huh:
I will try this again with the scan tool anyhow:cool:
As you are adverse to throwing parts (I agree), swapping parts location as Max has suggested is the recommended basic diagnostics.
FWIW, coil resistance reading may not identify a bad or weak coil as the plug state and fuel drench also affect detonation..
Your code reader may give you direction, a LIVE DATA SCANNER would be better.
Using an Oscilloscope would definitely show the full story (wave forms)..
... Philip
Discussion Starter #9
Misfiring
OK after swapping coils there were still some obvious misfiring , however the Car needed a drive in order for the car Computer to trigger a confirmed error ( still P304) , it took around 2 miles for the error to kick in after an initial unconfirmed/unverified random errors with a flashing engine light
So I changed the spark , now the car is purring again with all four cylinders . Thanks for the help guys .
Now I have to change the drum breaks cylinder ...
( new thread needed I think )
1 - 9 of 9 Posts
