1 - 10 of 10 Posts
Hi.
I could not find the O2 sensor.
I got errorcode P0135, indicating that O2 sensor need to be replaced.
Somone have a picture of the sensor, or a sketch where to find the sensor.
Thanks.
Vilfred.
Code P0135 occurs when the powertrain control module tests the upstream heated oxygen sensor's heater circuit on Bank 1 and detects a short in the circuit or excessive resistance in the heater circuit.
This is generally a wiring issue, check the wires close to hot exhaust... All way test before assuming code requires parts change..
Does a diesel have O2 sensors :unsure:
Missed that, did not realize it was diesel...
"Lambda sensors were introduced in 1977 to improve the efficiency of car engines. Fitted in both petrol and diesel vehicles, they help to reduce the number of harmful emissions, primarily gases such as carbon monoxide, and pollutants, produced by your car. Nov. 13, 2019 "
But I do not know if this one has an O2 !!
Discussion Starter · #5 ·
Hi.
Thanks.
Vilfred.
This is a diesel engenie. :)
Discussion Starter · #6 ·
Thank you for your answere.
I will check all wires. I only find temp sensors.
I would clear that code and see if it returns..
Looks to me like you have the emulator-mode of SZ viewer A1 enabled... so everything in the screenshot is fake.
I get exactly the same screen on my phone without the elm327 connected.
1 - 10 of 10 Posts
