Spend one hour to locate and open fuse box left of pedals.
Get a blanket on pavement next to driver door.
Kneel and use torch to find screws.
First remove the plastic grid by unscrewing two screws (x type).
Now turn your body to the left and spot the black fuse box!
Put a screwdriver inside the top hole to remove the lid.
Finally you have access to the fuses.
I had to replace the tail light fuse.
Alle the way to the left bottom corner.
Could not be more difficult.
To remove the blown fuse you need the fuse puller.
This and spare fuses are located under the hood in the black fuse box on the far right.
Now replace the blown fuse.
I was ready for coffee after this adventure!
I think I did it upside down on the driver seat....but anyway, I remember it as a kind of circus performance....
