I just had some work done on my 2010 Kizashi--had to replace the scrape guard and the left wheel liner because the bolts came out (boo!!). And since driving at night is now treacherous as only the daylights or high beams or fog lights work (none at the same time). I noticed that my lights seemed excessively dim and seemed to be pointed at an uppish angle.
Checked the lights in every possible setting position with the same results. When I looked at the beams, the lights nearest the grill has 2 bulbs and only the top bulb lights up (which explains the uppish angle). I would think that coincidentally that my night bulbs blew except that the in any position only one set works. And, the fact that the interior lights don't adjust like they normally do when transitioning from day to night lighting.
Has anyone had a similar issue? And is it possible that there is a sensor or switch that may have been messed up with the replacement of the plastic liner/scrape guard?
Check your ground side..
... Philip
