My liftgate suddenly stopped locking/unlocking with my keyless remote. Works fine when I use the key. I'm suspecting the actuator. I'll take it apart in a few days to clean, lube and inspect everything. My kids have a tendency of slamming the liftgate so hopefully it's a simple fix from the latch mechanism coming undone.
The reason for my post is to see if any of you know where I can locate a new replacement actuator (should I need it). Looked on Rockauto, Partsgeek and did a google search and couldn't locate any.
Thanks in advance.
If faulty, a junkyard part.
I've had the same issue with two of my four side doors, and find that installing the inexpensive ($6.00 universal) door lock motors work great! But I have not tried one in the back door.
[ame]http://www.amazon.com/High-Power-Door-Lock-Actuator/dp/B0002KR9PW/ref=sr_1_1?ie=UTF8&qid=1401969173&sr=8-1&keywords=door+lock+motor[/ame]
DO access your current actuator and probe the wires to ensure that you have power there now, to rule out a wiring issue up-stream first off. ;)
