OK need some ideas I have put a 9000 lbs winch on my samurai and now I'm about 1.5 inches lower than back. I own a welding/fab shop so building some heavy shackles would be no problem but I don't like the look and I've read lots of negative reviews. I'm going to do a spring over eventually with new springs but for now I'd like to level things out any suggestions. Thanks John
I'm sure you had your reasons, but why did you go with a 9k winch?
I think your best option might be to add a leaf, or, two, to the existing spring packs. Your probably going to need longer U bolts, too.
I had two winches laying around one was a 9000 the other a 12000 I opted for the 9. Thanks ill look into a spring
