A SPOA lift. (SPring Over Axel) This means putting the spings over the axels rather than under as from the factory. This will give you 4" of lift, then allows you to put larger tires on and give you additional ground clearance. Some people choose the easy way out by lifting the suspension with shackels but using shackels on your leaf springs will only create more problems down the road, ie(loose steering, added strain on drive shaft pinion angle, etc.) Try this site Offroad products for the serious offroad enthusiast!
