1 - 9 of 9 Posts
hey all
i just bought these
but havent been able to install.
i have connected the red wire to the internal button like this
and grounded the black wired to the screw that holds the switch in but when the door is open the led does not turn on - it will only turn on when i press the button in i.e when the door is closed (go figure)
i have tried to reverse the wires but it hasnt worked
any help would be great guys
thanks
Hi Krayzie,
Did you get your LED door sill scuff plates working properly? I just bought the exact same pair and am wondering how to install them? can you tell me how you eventually got them working please? Thanks a lot
You cannot wire the LED scuff plate to the door switch in that manner - the door switch shorts the wire to ground when the door is open.
Connect the red wire to a +12v feed and the black wire to the door switch.
Hi Fordem, my car does not have a visible switch on the door that tells the car when the door is open, I think its a sensor or switch on the inside of the door connected to the lock somehow. Would I connect the red wire to a +12V and the black wire to whatever wire leads to the door lock sensor?? Would this work?
I've never seen a car with the switch on the door - it's always been on the body.
Hey Guys. First Post here, but I am a long time modder of sorts, and hope i can bring a bit of knowledge to yall.
Anyway, From what I can tell from the pictures, That is not an LED rather an EL plate. As a computer modder, I am very familiar with EL wiring and that particular type of connector. Did the package include a transformer? From what i can tell, you will need the transformer to up the voltage in order to run them. You can pick them up in several computer modding websites such as Frozencpu, Performancepcs, or Xoxide. included with the transformer is a pigtail for running a momentary switch.
Hope that helps.
Positive wire needs to go to Battery and the negative wire goes to the Door switch.
Can you tell me where you got them from and can you get 'em for a Grand Vitara?
1 - 9 of 9 Posts
