What color should I paint my car with which wheels?
1 - 20 of 40 Posts
Kinkyllamas 04 dropped & blacked out forenza *UPDATED WITH VIDEOS*
Performance Stats (Will get these as I get time at the drag and with my gtech pro):
Curb weight; 2625# in street form, under #2550 in track form (haven't gotten it scaled recently tho)
1/4-Under 16seconds (I did 16 with far less mods)
0-60mph time-Under 8seconds (Did Just under 8 with far less mods)
60mph braking-???
100mph braking-???
Skid pad-???
Top speed: ~137mph according to GPS w/ old 5sp
Engine:
- 122whp and 133wtq at ~92 degrees with worst than stock tune (couldn't lean it out enough with current injectors/pump)
- Smt-6 piggy back unit (untuned)
- MSD DIS-2 ignition control (untuned)
- Boshart motor sports cold air intake
- 360 Dynamics UD pulley
- 4-2-1 Kinky headers
- 2.5" Kinky mid pipe w/ HI flow CAT
- 2.5 tapered into 2.25" Kinky Cat-back
- MSD coil pack
- MSD spark wires
- Upgraded grounds
- Optimal yellow top battery
- ARP connecting rod bolts
- Upgraded radiator
- Oil cooler kit
- 44lbs/hr fuel injectors
- 100lbs/hr walbro fuel pump
- Stiffened driver side motor mount and both lower mounts
- Breather hose open dump near bottom of the engine, with blue filter
- Oil filter relocation kit
- 15% coolant and redline watterwetter in the coolant system
- Ported (2mm) & polished TB
- Polished Intake manifold
Transmission/Drive:
- 6 speed F28 tranny
- 6 puck ceramic clutch
- 900lbs pressure plate
- Lightweight flywheel
- Qualife lsd
- Harry Hockly Drive Shafts
Wheels/Tires/Brakes:
- Street wheels; 17x8" 5zigen FN01R-C titanium bronze at 17.1 lbs each
- Track wheels; 17x8" 5zigen FN01R-C hyper black at 17.1 lbs each
- Blue lightweight lugs (saved about 3oz per wheel and looks great!)
- Street tires; 235/40/17 Falken FX452s
- Track tires; 235/40/17 toyo RA-1s
- Wilwood custom 2 piece 13" 4 piston big brake kit for the front w/ SS lines and 4 piston superlite calipers
- Stock size rear slotted rotors
- Hawk HPS Brake pads for the street
- Hawk HP Plus front brake pads for the track
Interior:
- G-force blue/black bucket racing seats for front
- 4 point blue harnesses
- Kinky Short shifter
- Blue leather shifter boot
- Custom painted blue panels
- Entire trunk (including sub box) painted black/blue
- Isotta shift knob
- Cobra 8500x w/ blue display radar detector
- Gtech pro SS
- Turbo timer w/ blue display
- Boost controller with high boost switch
- One (of three) interior dome lights is blue
- A/C lines insulated better
- Viper car alarm
- Innovative AFR w/ blue O-meter gauge
Exterior:
- Satin Black exterior paint job
- Fiber glass fender flares
- Reno front end conversion
- APR carbon fiber rear adjustable wing
- ARP carbon fiber front air splitter
- Fog lights
- 10000k HIDs for projectors
- 10000k HIDs for foglights
- Bluish turn signals
- Painted rear calipers black
- Rolled fenders
- Limo tint rear windows, one shade away from limo in the front
- Rear side markers shaved all around
- Blacked out tail lights
Stereo system:
- Kenwood deck
- Sirius satellite radio
- Ipod hookup w/ nano
- Spl 520vwatt max amp powering front components
- 6.5" CDT front components
- 3000vwatt max hifonics amp powering subs
- Two 12" kicker solo baric L5 subs
- Custom Baltic birch sealed subwoofer enclosures painted blue
- 0g wiring for subs, 8g for components
Suspension:
- KW variant 3 fully adjustable coil-overs
- Boshart Motorsports front and rear sway bars
- Rear lower control arm brace
- Mid chassis brace
Waiting to be installed:
- Boost, egt, and oil temp. autometer gauges
-Turbo kit waiting on a-pillar gauge pod and maintance issues; 8psi for starters on street
- Spare engine w/ Better rods and pistons for higher boost & 7200rpm redline; also lowers compression
- 3" turbo back exhaust, removable Hi-flow CAT, no resontor, apexi N1 turbo muffler
- Transmission cooler kit
- Battery relocation
- Kinky Front strut bar
- Lower mid chassis bar (to replace interior one)
- Reinstall front carbon fibre splitter (waiting on KDM lip kit)
- Install painted black/blue optimal batter, coolant resvoir, intake manifold, power steering resvoir, and other bits
Plans:
- Wilwood custom big brake kit rear (being developed slowly)
- oll bar with removable harness bar or roof bar
- Chassis trunk bar near struts
- KDM lip kit (working out import details)
- Cooler thermastat
- Stronger and lighter lower control arms
- Tubular turbo manifold
- Custom made shifter boot to perfectly fit short shifter
- Quick shift linkage kit
- Carbon fibre hood w/ satin clear UV coat
- Carbon fibre trunk w/ satin clear UV coat
- Port match intake mani
- Make brake cooling ducts for the front
- Try to move as much weight off the front as possible (...never ending)
- Getting more camber in the front (-1.7 to -2.8 depending how it feels and tire wear)
- Considering: Upgrade and add a brake master cylinder so I can adjust the brake bias if it feels needed after rear BBK
- Considering: Stronger and lighter drive axles from Taylor Race Engineering if I snap OE drive axles
- Considering: Cryo treating F28
- Considering: Remote start
- Considering: Intercooler spray kit with ice water (to stay track legal)
- Considering: Removing lift up reverse and shortening shifter furthur
Pictures:
http://www.daewootech.com/forum/album_pic.php?pic_id=2268
http://www.daewootech.com/forum/album_pic.php?pic_id=2267
Tearin' up the track taking a slight left turn at 80mph, note that the cars been lowered more since & my track wheels:
http://www.daewootech.com/forum/album_pic.php?pic_id=2269
New smoked tail lights, maybe 3 coats in and I think I did 5 overall with new rear bumper before we make some changes and get it to fit:
xs.to - Hosting
New front bumper, gotta get it to fit, paint the grill black, and mold the stock fogs tightly in place:
[URL]http://xs311.xs.to/xs311/07036/P1200142.JPG[/URL]
Trying to get a pass on an M5:
xs.to - Hosting
Trunk setup with old amp, new amp is silver (matching the subs) and the hifonics lights up blue(still gotta hide some wires):
http://xs110.xs.to/xs110/06503/PC120051.JPG
New 10000k HIDS (I have another kit for the fogs waiting to be installed). Still need to AIM them:
http://i192.photobucket.com/albums/z80/Kinkymotorsports/DSC00238.jpg
http://i192.photobucket.com/albums/z80/Kinkymotorsports/DSC00241.jpg
New reno front end (I ended up taking off the tint from the projectors):
http://i192.photobucket.com/albums/z80/Kinkymotorsports/DSC00166.jpg
http://i192.photobucket.com/albums/z80/Kinkymotorsports/DSC00163.jpg
New wheels, they will be track wheels once I save more money for wider street wheels. Also I banged up the fenders and raised the car to get them to fit untill I get my new fiber glass fenders installed. I could have probbaly gotten away with an extream fender rolling but I had these fiber glass fenders already and saw them on another car and they look pretty cool.
http://i192.photobucket.com/albums/z80/Kinkymotorsports/DSC00235.jpg
http://i192.photobucket.com/albums/z80/Kinkymotorsports/DSC00227.jpg
10000k HIDs all around. Fogs have pretty bad glare--I'd like to retro fit them but that depends on cost.
http://i192.photobucket.com/albums/z80/Kinkymotorsports/DSC00354.jpg
I love how the bronze brings out the brakes... (before lowering this corner .35")
http://i192.photobucket.com/albums/z80/Kinkymotorsports/DSC00350.jpg
Before lowering the other three corners .6-.8"
http://i192.photobucket.com/albums/z80/Kinkymotorsports/DSC00364.jpg
http://i192.photobucket.com/albums/z80/Kinkymotorsports/DSC00361.jpg
A look at one of the fender flares:
http://i192.photobucket.com/albums/z80/Kinkymotorsports/DSC00345.jpg
Videos:
Half throttle trying to get a good pass on the car infront. You can hear me go full throttle on the second to last corner and I passed the car shortly after on a small straight:
YouTube - My 04 forenza at PIRs roadcourse
Trying to keep up with a really fast 350z out at PIR roadcourse in Arizona:
YouTube - 2004 Suzuki forenza at PIR
Questions and comments are welcome!
Danny
God dam kinky you got a shit load of stuff in your car. The 0-60 time is impressive tho. And the 143MPH plus is as well. I think you need a new speedo.:p But have you tune your car yet or is it still not tuned.
pearlesant black paint + or - white or flat black clean looking pinstripes
black powder coat wheels
or
two tone pearl black and flat black
powder coated wheels
Discussion Starter · #4 ·
No tune, less than factory I would assume sicne we needed to lean it out cuz of the high flow fuel pump and injectors...and still I had to replace the injectors untill the turbos on anyways and havent tuned since.
or
Nah, either I'm going to keep it the way it is or do a flat black. I'm sticking to solid black as I'm not a fan of pinstripping and the only reason I'd bother getting it repainted flat black is its cheap, this isnt a show car. :D
I'm just thinking the flat black would give it more of a race/mean look and would go better with a carbon hood, my carbon splitter, and my carbon wing than the factory black.
Dark Charcoal -- close to black -- with lots of metallic tint. If you go flat black, you're gonna look like you couldn't spring for decent paint. Go for a very dark grey metallic -- it'd be killer.
Black with bronze rims looks like an old Trans Am from 1983. Don't do it, man. If you do, I'll get you a nice bronze vinyl thunderbird decal for your hood...
Or, take one from the off-road playbook -- go with black Rhino-liner. I don't think it'd ever scratch, but it's not very aerodynamic, either.
Discussion Starter · #12 ·
Maybe I'm not gonna bother painting it at all. The only reason I considered flat black is it's cheap, still black, and kinda mean looking....but mostly cheap.
I think bronze wheels give it more of a race car look to it. Though not ricer race...just race. Maybe thats just cuz I see allot of race cars out on the track with bronze.
I like black cars. Probably the only colour car I'll ever have.
And I like that flat black look a lot.
Very nice. You definitely should go with it if you decide to paint at all.
Awesome to see someone do something so original with a Forenza! I actually think the grille looks good as is - maybe billet in the two side ports, but leave the Zuki emblem in the center for sure, don't want it to get too generic looking or have people constantly ask "what is that" (you probably get that enough already).
you'd be surprised. ive seen about 3 or 4 other renos around here about 4 months after i bought mine. before we know it, they're going to be as popular as some of the other cars that we all can point out from 500 feet away at night by just looking at the head/tail lights...
i like the way it looks right now, Danny. even some silver enkei's would look nice on it. i can be pretty judgemental about rims on cars...dont get anything too flash or too detailed when you're driving a sporty car. and vise versa...i know you are going to be looking at racing wheels anyways, but for those who are reading : unless you are going to make it look lux and keep it quiet, dont get flashy rims(please?).
i shaved all of my badges except for the steering wheel(pain in the ass to change). i think it looks more professional and sleek without them.[/rant]
Discussion Starter · #20 · (Edited)
I started thinking about it, I never hit 143mph, I hit 133mph...but since then I hit 137mph at close if not 6k rpms so theres no way it'd go any faster without bigger tires or higher gearing. After using my gear calculator it says at 6k rpm with my street wheels I'm at 136mph. I'm having a hard time beleiving the speedo is that correct. Im going to bring my gps with me one of these days.
1 - 20 of 40 Posts
