It's got t3/t4 turbo running 10lbs boost untuned. Definitely a quick little jeep. Runs strong, but it will have to come out one last time to repaint the whole car smoke metallic grey, hide the wires, and get it tuned. A lot of custom fabrication and welding was done. Countless hours and setbacks. But well worth it. Thanks.
Looks like it barely fit. Nice job.
One suggestion. Come up with some kind of a heat shield for the plastic brake fluid reservior. I'll bet that turbo will get hot.:eek:
THIS IS MY DREAM CAME TRUE , can you tell more detail ? can you tel me if you use the sammy gear box ,and clutch ,body lift ,modification to the computer etc?
or where can i get more details a bout this job ,
thanks and EXELENTE JOB
Yep
This was my dream also, and now i'm livin' it with my sammy.
Too many modifications, basicaly need everything from a 240. motor, transmission, gearbox, driveshaft, ecu etc,
its pretty much just using the sammy as a shell, email me at
[email protected] if u want more info, i will be doing another soon.
