Hi - my 2005 1.3 Jimny with DOHC engine has a misfire, I've followed forum advice and bought a new cam (now fitted) and crank sensors. This sounds stupid but I cant find the crank sensor on the engine - (or the supplier has sent me a wrong one) - it would be a great help if someone could send me
a pic of the bare sensor and where it is located on the engine
crank sensor position
the sensor is located behind the alternator and is held in the block with a 10mm spanner size bolt. you need to remove the alternator belt and move the alternator back to gain access.:)
Crank sensor
Thanks, Ive fitted that one + mistakingly thought it was the cam sensor,
where is the cam sensor please ? - I have the new one but can't find the original one on the Jimny?
Thanks for your reply
Jim
cam sensor position
follow the rocker cover to the back of the engine bay .the cam sensor is to the left of the engine down where the inlet manifold ends. once again 1 10mm spanner size bolt.
