I have a 2011 Suzuki grand Vitara and none of the interior lights have ever worked since I purchased the vehicle. I’ve tested all of them and there is power to all, I can turn my dome light on manually. I’ve checked the interior fuses and replace them and it didn’t do anything. I’m not sure what else to check or what else it could possibly be.
Any suggestions would be appreciated. I have read through the other questions posted and saw some thing about a fuse under the hood which I will check but I am not sure if there is anything else it could be if it’s not that. Thank you in advance for your help!
Also I assume when you shut the car off the door should automatically unlock or lock when you put it into drive and it doesn’t do that either not sure if it’s related.
