hi Renza429 welcome to the forum! of course there is, all you have to do is remove your intake lolol you have a couple of options for an intake. first theres the premade rout. right now i think theres only one intake for the car in production. its made by weapon-r and i believe its a "secret weapon intake". i dont have one but ive heard good things. another option is to build your own. a company called spectre or specter has all the parts you would need to build one. there a company that makes do it yourself parts. or what you can do is buy one for cheap off ebay you think is close to the right shape and cut it and put it together so it fits. not my suggested way because you never know what your going to get or how much work will be involved. or just buy some pipe and make your own. heres some info about making your own;yoiu want to run the intake the same rout as the stock intake. youll need to use 3inch piping. you need a 90 degree elbow to come off of the throttle body. silicone is probably best for the elbow piece. then a straight pipe, sorry i dont know the length of pipe youll need. then i think its a 45degree bend to get you from the back of the engine around to the side. then straight pipe. now you could stop there with it behind the headlight or you could run it down behind the bumper. if you go down by the pumper of course youll need another bend. the stock intake isnt the easiest to remove. once you get all the top pieces off, if i remember correctly, you need to remove the splash shield from behind the tire and under the front and pull the air box out that way. you might have to fight with it a little bit. i think thats about it. any other questions just ask
