Hi All
I have a Suzuki Carry Van and I want to install a large display fridge running on mains voltage (UK 240v).
I'm intending to install a volt sensitive relay, a leisure battery going to a voltage inverter powering the refrigerator.
I have attached a diagram of what I'm intending to install, if anyone has experience with this sort of thing could you take a look and let me know if the plan looks feasible.
Also does anyone know if the alternator on a Suzuki Carry is sufficient to charge and maintain a battery powering a full sized refrigerator?
Many thanks
-joe :)
You would probably be better off with a gasolene generator powering the fridge.
Start by determining the power consumption of the fridge - both start & running current draws - without that you're just guessing. Next, ensure that your inverter can run the fridge - inverters, as a general rule, do not handle inductive loads well, and your fridge is likely to have a significant "start-up" current draw.
Once you know the running current, we can maybe guesstimate the duty cycle, which will determine whether the alternator can handle the load, which I doubt.
