1993 Suzuki Vitara JLX, Greek market, 1.6 liter, 8 Valve, soft top, manual…
Just bought the cheapest 4x4 on the entirety of Greece. Runs good. Cel is off on ignition. Will check bulb. But I want to fix oil pressure light first. With ignition on, the oil pressure light will not go on. With engine running and the oil pressure wire disconnected and grounded on the block, the light will come on. With engine off, there is continuity on the switch top and ground on engine….with engine running there is no continuity. So the oil pressure switch seems fine. Also bulb is fine…but bulb does not come on with ignition on. Any suggestions welcome.
