as the topic says...the fuse keeps on blowing ever so often..might last 5 mins then blow..might blow as i put it in..i dont know what to do:mad:
you've got a short to your ignition coil. It's either in the coil itself or it's in the wire loom. I'd replace the coil first... since it's like 10 bucks. If that doesn't fix it, Trace the positive wire to the coil and see if you can find where it's insulation is broken and it's grounding out.
