Hey guys! So I was reading that I will need to bypass an ignition interlock. Which I assume that is what keeps the key from coming out without being in park. I'm doing a manual swap in a Geo tracker and know I gotta bypass the neutral safety switch. But was curious if I'll need to bypass the ignition lock or not. Any help would be greatly appreciated!
You don't absolutely need to, but if you don't, you won't be able to get the key out ;)
There's a cable from the shift lever to the ignition switch. I've never needed to do it, but I don't imagine it'll be too much of a challenge - remove the cable and replace it with a piece of stiff wire (maybe a paperclip), bent to hold the mechanism in a suitable position.
