1 - 20 of 28 Posts
Hi I have recently purchased a 2018 Ignis adventure I have managed to connect my phone via Bluetooth but whenever I try and set up android auto I can't seem to get it to connect anyone else had any issues?
connect via Bluetooth then use a good quality cable, not the crappy charger cable it comes with
My 67 plate (late 2017, let's not repeat the number plate discussion) required a software update for Android auto, which either the dealer can do or you track down the files online and update it yourself.
Mine is a 99, but has a Veteran plate...
The guide I watched says (and it makes sense) connect via USB cable then Bluetooth. This will only work if the unit in the car is WiFi compatible as I found out. Mine works perfectly for what it's worth but only with a USB cable connection.
As others have said. Android Auto will only work wirelessly if you have wireless compatibility built-in to your Infotainment system. I have a 2018 Ignis with a Bosch type unit the same as many others and the unit won't work wirelessly. It will only work with a USB connection.
Discussion Starter · #10 ·
I cant even get my 2018 Ignis to recognise that there is a phone plugged in with a usb cable but works ok with a iPhone. I have tried various different USB cables and nothing works.
Suzuki Ignis 2020
You will need to update the firmware on the radio for it to work, had the same problem
Good quality USB cable is a must. Cheap and cheerful ones will almost certainly not work. I have many cables and only the more expensive two or three work.
I thought I had a connection problem too and I did - the cable!
If after all this you are still not connected then I'm afraid you could have a phone model that simply won't connect.
We have had a few issues with the Suzuki units not working or not working properly (connecting and disconnecting Bluetooth) and the particular phone makes a big difference.
Our Huawei phones are troublesome but Motorola and Samsung seem to work fine.
This is the first car we have had so much trouble with.
I should say this is the first Infotainment system as it should not matter the car.
First car I had great phone connection with was my 2011 Nissan Juke. Connection was first rate. Moved to Skoda and their systems which was not as up-to-date and they were a bit of a let down but still worked. The Suzuki - not so good again but the phone brand would appear to make a big difference - at the sake of repeating myself. If you have a Samsung or Moto lying around or borrow a friends' and see if it connects better but, remember a good quality cable above all else.
I have seen many occasions where intermittent or no connection was down to a bad cable or loose cable connection - usually at the phone end. Cables are cheaper than phones to replace so the phone port will probably be fine.
Hope all this helps.
I'm just curious as lots of people say use a high quality cable. What makes the difference between a low or high quality cable. Is there any way people can easily identify if the cable is up to the job?
Usually a quality cable is a known brand name but not always. I have used Adata lately. A USB 3.0 Gen 2. Others have said they've had problems with USB 3 cables. I believe either USB 2 or 3 should work equally well. I'm ex electronics workshop and experience with computers.
Good cables are typically more expensive.
Excellent input. Many thanks. Very helpful.
My four-year old S8 has been particularly flaky connecting for a month or two.
I've just bought a S21 and it's perfect - with the same cable.
Hence I'm sort of concluding that the connector port on the S8 has been damaged over time.
Sounds like it. A shame because the ports are made to be more robust than the cables BUT they are still only copper.
I had this issue extensively due to a knackered USB c port on my phone. I backed a wireless android auto indiegogo project about a year go that came a few months ago and it's been perfect with my ignis.
Good to know the wireless adapters work well. Could be a good option for people.
What is the name of the app. Sounds worth a look. Thanks.
1 - 20 of 28 Posts
