Hi,
I have heard that it is possible to rebuild Jimni's 1.3l engine with 1.5l Ignis block. I would appreciate any information. May be someone who has done it already would comment. I don't know if variable valve timing of Ignis will not conflict with engine computer of Jimni that has no VVT. :confused:
Regards
Jurek
The G16B has been swapped into the G13BB engined Jimny a few times so if it is a G15 block it should also fit a G13BB engined Jimny. You may need an adapter plate similar to the G16 into a Sammy conversion. The M13A engine has a different bolt pattern. The VVT set up will not work with the stock ECU.
Ok, I understand that VVT will not work. In fact I may do a simple, separate controller for it. But I am curious if other systems (sensors for example) of 1.5 VVT will be compatible with ECU of Jimny.
