Ignis double din
Hi! I'd like to put a 2din head unit in my 2002 Ignis.
I already managed to remove the original clarion unit, but i have a couple of questions:
-is there a 2din fascia for my car? Has anyone already tried this? Is this possible?
-I have already unscrewed the front panel and the 4 screws of my original black cage (that cover the 2din hole with 1 din for radio and the "open space drawer") but i am not able to remove the lock "behind" the cage...than i can't remove the cage. Do you have any suggestions?
Thank you very much! :)
I'm sure you've sorted this by now but..
I had a similar problem but i only wanted to take the cage out to tap into the power antenna wire to add a remote turn on for an amp ... I ended up drilling the head of off the Philips M5 screw in the center of the cage (its the only screw holding it in)... it just wouldn't budge...once the head of the screw was removed the shaft came out very easily so i replaced it with another on refitting.
as for the double din fascia ..
Celsus Suzuki Ignis 00-06 Black Fascia Double DIN - Celsus from NP Autoparts UK
