Hi, I have a 2010 crossover JLX with keyless everything and I tried to install a new radio, at first the new radio wasn't working and it worked a couple month ago when I 1st tried it, then one (or more) of the radio wires sparked....
I turned eveything off to prevent more fuses blowing up... After doing everything properly with the wires I tried to turn the ingnition to ACC....
Like I said I TRIED... The ingnition switch will not turn even if the KeyFog is near and the dashlight indicating if the fob is present or not will not light up, the radio still dont work, the electric doorlock dont work either (keyless and the button inside the door). I have a check engine light which I cannot check the code cause my code reader dont seem to detect the OBD2 and yes I tried in another car and everyting worked well...
And a dashlight representing a car skidding flashing for about 2 or 3 minutes then stop and it does it again each time I start the car with the KEY cause the fob still dont work...
I have checked just for fun the following fuses :
ACC
ACC2
Doorlock
I unplugged the battery to give a chance to the ECU to maybe "reset".
Other then that I have no ideas what to check
Discussion Starter #2
Ok, for some reasons all the keyless fonction are linked to the DOME Fuse.... Isn't it the fuse for the dome lights?????
Changed it and everything work, go figure.....
Thank you for reading ;)
Welcome to the forum.
Glad you sorted it :thumbsup:
It's quite normal for that fuse to cover quite a few circuits.
This is from the SX4 until 2009 just as an example.
