hey all so i have a question i istalled H.I.D's on my verona and i have to pull my e-brake during they day because i drive alot of short distances all day and i dont want to burn out the buls so i use the brake so the daytime running lights turn on because they dont produce enough power to fuction so they flicker and i dont want that to mess them up. anyone know how to fix this if i can pull fuse to stop they daytime running lights or anything.
to disable your daytime running light. there is a fuse box located under the hood on the driver side, its black in color, open it. look under the cover and it will show you what every fuse do. look for the location of the fuse that have DRL* on it and disconnect the fuse and your daytime runnig light will not turn on ever again, but keep in mind that on your dash(instrument cluster) it will still have the DRL indicator but the light will not be on. good luck
