I have been driving my sammi for the last 6 months without a vibration.
Now I was driving home when all of a sudden I started to feel a bad vibration.
I got it home and started to look at the motor and it was clean.
I replaced the motor mounts, and 4 u-joint and now the vibration is between 3 and 4 grand in second gear.
I have tried to line up the drive shaft. I believe I got it.
I am thinking about getting new transfer case mounts but can't figure out where to buy them to get them fast. I have read some posts about a polaris transfer case mounts but can't figure out where to buy them
Its doing it in 2 wheel drive.
Any suggestions. I am staring at this thing and cant figure it out.
CJM,
Check the U-Joint up where is comes from the trans. It is a short one up high near the transfer case, but it looks like you got that one, I think. Have you made sure that the front hubs are unlocked? Crawl under try to rotate the front drive shaft, it should spin.
I bet it is the small drive shaft between the trans and t-case. Just move it and see if there is any play. If you already replace some u-joints, you should know what I mean.
I got it fixed thanks for helping it was the driveshaft I did not get it set up right like i thought. Thanks
i was going to say the middle shaft too...Mine did the same and one of the guys here told me how to check it with the T-case in neutral and that was it,new u-joint and all was good...But sounds like you got it...
