I believe my window switch is going bad. It only works sometimes in the up or down direction. When it does work the travel speed in normal.
Problem is that I cannot remove the cluster module from the door. If I try to pry the cluster module with a flat head screw driver it bends the screw driver pretty badly but does not seem to budge the cluster.
Does anyone know how this is removed?
window motor
its not switch its a window motor. there are 4 screws on the door, 2 bottom and 2 on side( covered by plastics caps remove first). life the door panel and you can find the door switch and motor all, easy fix takes little time
