I have a 1996 Suzuki sidekick and I am trying to install spot lights on the grill and I can not find a way in the cab threw the engine compartment somebody that knows how's help out please
I usually follow the main wiring loom and then carefully drill a hole thru the firewall beside it and fit a waterproofing grommet with cable skirt (its like a grommet but has a rubber tube you cable tie around the cable to waterproof it).
Of course you must check you aren't going to damage anything when you drill the hole.
