Got my first car, a swift 2006 :)
Anyway, how do I clean the rust off of the wheel hub? Obviously I know I need to take the wheel off etc but what tools do I need to clean and then help protect it?
I have included 2 pics, first of the whole wheel (sorry a little hard to see) and 2nd, a close up so you can see the rust.
A wire brush, some coarse sand paper & high temperature paint - I'm going to bet that after a few cycles, you'll become frustrated and just leave it - I certainly did - you might have better luck with one of the newer VHT (very high temperature) paints with ceramics, they might last longer than the old high temperature stuff, what I used was supposed to survive exhaust manifold temps, but it never lasted more than a few months on the drums.
By the way - that's the brake drum, not the hub - a large chunk of cast iron, and apart from being unsightly, surface rust doesn't harm it.
thanks for the terminology update. I spoke to some guy at work and described it as "what the wheel is bolted too" and he said it was the wheel hub.
I had a browse on google and a lot people have said similar to you with most saying to use a wire brush adapter for a power drill and use that. Also a few have mentioned using the following to coat it.
Halfords | Hammerite Direct to Rust Metal Paint Hammered Silver 750ml
The wheel does bolt to the hub, but you can't see the hub in that picture, the brake drum is what you're seeing - as for your choice of paint, brake drums get hot, rear drums, not so much, you want a paint that can withstand high temperatures or it will just burn off - Hammerite does make high temperature paints, I strongly suggest you use one.
