Hey guys I am looking to figure out how to adjust the rear camber on my Optra/Forenza. I have a negative camber at the moment and the inner part of my rear tires are wearing down to steel belt. Any help is appreciated, thank you.
HI the rear suspension adjustments are behind the wheel on the suspension components. unless you know what your doing the only way to get them set right is to take the car in and have an alignment done. in the rear you can adjust for toe and camber and in the front i think just toe. if you want to try yourself there are ways to do the adjustments. look online im sure there a bunch of how to articles that tell you how to set everything up.
I have thought about this and have decided to leave it until I replace the rear struts. They're pretty bad and once they're replaced I think it should straighten back out when they're done. Thanks 7
