My fan became intermittent then stopped. Since I couldn't find any tutorials on how to access the blower I'm making one for the next poor guy. Here are the steps, (pix to follow in an update once I take them).
1. Open the glovebox and empty it. There is a small plastic phillips screw on the lower right. Once you unscrew it it backs out enough that the screw and its housing pull into the glovebox allowing it to pivot forward and out of the dash on the right side. Then the left side unhooks naturally.
2. Ignore everything except the white plastic housing on the right. There are two nuts on top of it holding it to the firewall bolts, 11mm.
3. Also loosen but don't remove the 12mm nut hidden under the left side of the housing, between it and the black air passage on the left. I needed a moderately deep socket, an extender and a ratchet. The housing will slip off to the right before the nut is entirely removed.
4. You will probably need to disconnect the resistor plug in the middle front of the housing, and the power to the motor under the right side of the housing. My power plug was burnt from a short, explaining the whole problem! (And that odd smell last week…) Happily, after wire brushing and heat shrink tubing the motor works fine again at all settings. Win!
Sorry if you need to access the fan switch in the center console. I couldn't find any way to remove that. Hopefully someone has a link they can post here for the next poor schlub!
Good luck, Rick
Good luck, Rick
