hi
my mate poprodder posted something earlier for me but now i have reg. i can explain a bit more.
i have just bought a vitatra QJLX FAT BOY "H" reg. the horn works with the ignition switched off but as soon as you turn the ignition on the horn won`t work. has any one had this problem before, if so can you help...
Hi, just had this prob myself and contacted main agent who were aware of the fault and told me it was almost definatly the earth. Either broken or bad connection. sorry it took so long to answer :thumbsup:
:) Hope this helps I had same problem, you have a rubber type shock joint on the steering column in the engine bay it will have an earth wire going from one side to the other replace this and you will have fixed your problem.
