1 - 11 of 11 Posts
Hey guys.. So didn't drive my 04 vitara for about 2 days, start up today and turn on the ac and the horn starts blowing not at ful volume but its on.. Then I notice my indicator light and 4wd light on in my dash without me turning them on.. Any advice as to where to begin to look..??? Confused
Under the dash for a bad ground connection - what is your experience troubleshooting electrical issues like?
Not the best at electrical but I'm no dummy under the hood if u know what I mean. now to think of it I've bin also experiencing some what of a short wher the windows don't work momentarily any pointers on where to check for bad grounding?
Yes - I know some excellent mechanics who are hopeless with electricals, they say it's because they can't see the electrons moving ;)
My suspicion is that the ground issue is related more to the HVAC blower rather than the A/C itself - I've attached a pdf that shows where the under dash grounds are, the image is for a RHD vehicle, for LHD it's a mirror image - just locate all three and make sure they are clean & tight - maybe unscrew them & shine them up with a wire brush or sand paper.
There are three ground points, one in each "foot well", behind that plastic cover just in front of the doors, and the third under the center console - the ones you need to focus on are the ones in the foot wells, and the power window grounds to one of those so that might be related - I should go check that one on my car - there's a distinct slow down if I have more than one window moving at the same time.
Discussion Starter · #7 ·
Hey fordem found 2 of the three grounding points not finding the center one I also disconnected the blower motor and problem still there. Mind you the grounding point I found seem to be fine as there were tight and no corrosion I jus can't seem to find the the center point.. Which is strange where else can I check
Discussion Starter · #8 ·
Aye Fordem finally found the issue it was the harness behind the battery.. Was shaved ND wires were crossed. Now I fixed that having issues starting.. The pump doesn't seem to be running when I plug it up.. The pump runs when bench tested but nothing when plug up.. Has power in the connector n all the gas gauage reads but nothing from pump
Start by verifying the ground circuit, voltage drop test (loaded)..
1 - 11 of 11 Posts
