Hi all
Just failed mot on emissions ,co fine hc fine ,lambda too high (about 1.033), ie weak mixture.
Have been through all the usual suspects changes O2 sensors and maf no leaks to be found runs fine but not much power but it's only 1.6 auto anyway.
Fully serviced
Any pointers?
Cheers
Mike
Check your static engine timing....
..... Philip
thanks Philip , I thought this was set by the crank sensor?
cheers
Mike
The static engine timing is the relationship of the valve train to the crank, all mechanical, timing belt..
The crank sensor detects changes in crank speed during revolution (missfire)
...... Philip
