My high beams on my 2001 Grand Vitara will not come on when the switch is forward. They work when I pull back the switch to "flash" but do not come on at all when I push the switch forward. Low beams work fine and high beams work when flossing, but don't stay on. So I don't think it is a fuse, just not sure how to fix….?
For a part number, you'll need to let me know where you are - at least the country (or which country the vehicle was built for), because there are different switches, and I believe you can reach the switch without removing the wheel - the column shroud usually separates into top & bottom pieces - although you may have to remove the wheel to remove the switch.
