hey i recently changed my clutch and pressure plate since then i have been getting really hi revs and low speeds i am even able to pull off from a dead stop on 5th gear .....some guys suggested that it was a low diff ratio but i really dont know does the transfer case gearing have anything to do with this ......oh and my hi way speeds are really slow with the engine revs really high 6000-7000 and only about 55km.................what ideas do you all have on this
Slipping clutch is possible. You may find that there is no solid connection between you rpm and speed if that is the case.
The effect that the transfer case has on the gears is that there is a low ratio range which gives further reduction in the ratios. Make sure you can cycle in and out of all the transfer case selections and that they operate correctly so you know you aren't stuck in low range.
