I have a 1990 samurai it died and won't start it has a new fuel pump and it is getting fuel but I'm not sure if the injector is working has any of you had a problem like this I can dump gas in the TB and it runs till gas runs out
Its quite likely to be an ECU problem, the ECUs are quite old now and if it hasn't been replaced to refurbished then it may have failed capacitors. Does the injector fire at key on? can you hear the fuel pump relay click on and off at key on?
