Are those not two totally different body styles? :huh:
Subtle diff maybe, but....I would assume no correct fit.
Will a 95 geo tracker soft top work on a 01 Chevy tracker
While I haven't actually TRIED it, but considering they are totally different bodies... I'd venture a guess...
NO.
It's not subtle at all - the 01 is a larger vehicle, wider and longer - it will NOT fit.
Discussion Starter · #5 ·
Thanks for all the help. But the length and width were right on. The only problem was the angle of the side windows.
Yep. Subtle difference. :rolleyes:
I hope that you find what you need. Try the our classified section.
Provide your location under "User CP". That might scare up local possibilities from anyone reading your posts here.
