Good evening
Can you please assist am the new kid in the block am doing repair on the jimny 2010/2009 somewhere there the vehicle is not starting I checked everything following the diagram but am not winning please help
You need to tell us what happens or does not happen - does it crank, do the dash lights come on, is the check engine light on - remember, we're not there with you seeing & hearing...
Thanks and yes its does crank the ignition but not picking up for idle vehicle was on accident has been repaired once I turn on the ignition the lock key flash on the clutch I diagnose it's says engine faulty when I erase the code it's say success but nothing happens also the is ecm massage comes in
what ECM message? what code?
Depending on accident severity the SDM module may have locked the ignition out to shut the engine off. Can you provide a list of exactly what has happened, and what it is, or isn't doing please.
